A component on the management module failed to open an IP connection socket during I/O blade initialization. Look up the errno definition for a more specific cause.
Initialization of the I/O blade will fail. Disable and enable the slot. Report the problem to the switch support contact.
Error
An attempt to open on an IP socket failed retuning errno %errnoNum%(%errnoStr%) for slot %slotNo% and conduit Type %cndtType%.
| Name | Type |
| errnoNum | uInt |
| errnoStr | String |
| slotNo | uInt |
| cndtType | String |
